查看: 13|回复: 0
VITA STANDARDS LIST,VITA 最新标准清单大全下载_ansi vita
发表于 前天 10:07 | 显示全部楼层 |阅读模式
Designation                Title
! A3 H" U! m* n0 E* {: \' d VITA STANDARDS LIST,VITA 最新标准清单大全下载_ansi vita.pdf (1.08 MB, 下载次数: 0) 7 W7 z; k9 P% f% R1 e" l( J
0 S$ d4 k8 z# l. Q- k
* a$ M) ^$ h, y; fVMEbus Handbook, 4th Edition        ' u0 o* l5 j( \; i+ Y
ANSI/VITA 1-1994 (S2021)        VME64' g0 E: j  O, ?
ANSI/VITA 1.1-1997 (S2021)        VME64 Extensions( m0 t4 G9 U- r3 V$ i" K% c
ANSI/VITA 1.3-1997 (S2021)        VME64x 9U x 400mm Format
7 H6 p8 ~3 V5 U) nANSI/VITA 1.5-2003 (S2014)        VME 2eSST, Y! Q  y3 J/ p9 a
ANSI/VITA 1.6-2000 (S2021)        Keying for Conduction Cooled VME64x
, K0 I3 X7 t$ n  B8 ~- FANSI/VITA 1.7-2003 (S2014)        Increased Current Level for 96 Pin &160 Pin DIN/IEC Connector* I  H$ a' H) K/ H. x4 w4 |
VITA 3-1995 (S2022)                Board Level Live Ins***ion for VMEbus
& h5 R- _! M% a7 |1 BVITA 4-1995 (S2022)                IP Modules# R4 v8 z0 n. P) u4 c
VITA 4.1-1996 (S2022)        IP I/O Mapping to VME64x
; d2 j# h" u, f3 `; qVITA 5.1-1999 (S2022)        RACEway Interlink on VME
* Z0 w( Y$ e" u: FVITA 6-1994 (S2022)                Signal Computing System Architecture (SCSA) on VME
. d" r: [* x5 L, D) R; d, h: i$ nVITA 6.1-1996 (S2022)        Extensions to ANSI/VITA 6-1994 Signal Computing System Architecture
6 X5 S2 x" M+ nVITA 10-1995 (W2012)        SkyChannel Packet on VME P2
; @3 y7 {2 E9 T# g- BVITA 12-1997 (S2022)        M-Module
3 e5 _7 {, P& a3 K' CVITA 13-1995 (W2006)        VMEbus Pin Assignment Standard for ISO/IEC 14575 (IEEE Std. 1355-1995 (H.I.C.))$ h0 ~7 h) j# K0 y8 j2 I6 \
VITA 17-1998 (S2022)        Front Panel Data Port (FPDP)
$ @+ C$ P; h  tANSI/VITA 17.1-2015 (R2022)        Serial Front Panel Data Port - Y. e5 @& x7 S1 a4 I0 |: ?/ @
ANSI/VITA 17.3-2018        Serial Front Panel Data Port (sFPDP) Gen 3.0         Serial Front Panel Data Port (sFPDP) Gen 3.0! a8 l1 Z% C: ]4 g3 B# W* @
VITA 19.1-1998 (W2006)        BusNet Media Access Control (MAC) Standard4 \! H5 o# U4 Q4 M1 `& \' ]
VITA 19.2-1998 (W2006)        BusNet Link Layer Control (LLC) Standard# N! @; X! S, C1 ~
ANSI/VITA 20-2005 (S2018)        Conduction Cooled PMC
/ [' y( V) B/ ]! ^* {6 x8 v5 uVITA 23-1998 (S2022)        VME64 Extensions for Physi** and Other Applications
3 b- Y9 Q& D( lVITA 25-1998 (W2006)        VISION (Versatile I/O Software Inte***ce for Open-bus Networks)
% ^5 O3 b. |1 f6 sVITA 26-1998 (S2022)        Myri***-on-VME Protocol Standard
, g' y( t. `3 u, F# J* T6 `VITA 29-2001 (W2006)        PC*MIP
7 S! N* ^% C0 h( [# EVITA 30-2000 (S2022)        2mm Equipment Practice for Eurocard Systems
: K0 }1 b2 H8 S: K- cVITA 30.1-2008 (S2022)        2mm Connector Practice on Conduction Cooled Euroboards- z/ Y9 {* f! u) f; v
VITA 30.2-2001 (IEC)                Power Connector Equipment Practice2 `+ L& r5 n1 R* ]8 v
VITA 31.1-2003 (S2022)        Gigabit Ether*** on VME64x Backplanes6 W$ b/ ?6 Q" C
ANSI/VITA 32-2003 (S2014)        Processor PMC0 r$ R1 z# H7 E& w4 z
ANSI/VITA 35-2000 (S2021)        PMC-P4 Pin Out Mapping to VME-P0 and VME64x-P2  I; a# D% U( m$ x$ F; E1 Y
VITA 38-2003 (S2022)        System Management on VME
/ V  G/ }& o* O5 J$ Z! |( nVITA 39-2003 (S2022)        PCI-X for PMC and Processor PMC
  {: n8 S( {+ HANSI/VITA 40-2020                Service and Status Indicator Standard         Service and Status Indicator Standard) J1 m/ _8 _' W8 Q- _* `
VITA 41.0-2006 (S2022)        VXS VMEbus Switched Serial Standard) b9 H0 f  k" s; W6 l4 g" `
VITA 41.1-2006 (S2022)        VXS 4X InfiniBand &*****rotocol Layer Standard
4 M# q' G4 b; K" w6 ]5 C- F/ rVITA 41.2-2006 (S2022)        VXS 4X Serial RapidIO Protocol Layer Standard5 J0 F6 `, l  I0 L- j
VITA 41.6-2009 (S2022)        VXS 1X Gigabit Ether*** Control Channel Layer Standard
3 h/ _, Z5 q2 aANSI/VITA 42.0-2021        XMC: Switched Mezzanine Card (XMC) Auxiliary Standard: \0 j' u4 ?6 F7 Z# G
VITA 42.1-2006 (S2022)        XMC Parallel RapidIO 8/16 LP-LVDS Protocol Layer Standard
% |6 K# U# o0 iANSI/VITA 42.2-2006 (S2018)        XMC Serial RapidIO Protocol Layer Standard
& g2 o4 Y( j( q2 e8 m: E' u6 _ANSI/VITA 42.3-2020        XMC PCI Express Protocol Layer Standard
% m. N, P' }8 wANSI/VITA 42.6-2009 (S2024)        XMC 10 Gigabit Ether*** 4-Lane Protocol Layer Standard8 T2 N7 A2 C) }: C, L
ANSI/VITA 46.0-2023 +Errata        VPX Baseline Standard
, t. Q) W! b( d9 m5 yANSI/VITA 46.1-2007 (S2018)        VMEbus Signal Mapping on VPX( [( X  H  w( U& Q: T
ANSI/VITA 46.3-2012 (S2024)        Serial RapidIO on VPX Fabric Connector
/ L0 R$ _/ N+ k- D2 t  u/ T8 A4 KANSI/VITA 46.4-2012 (S2025)        PCI Express ®on the VPX Fabric Connector# K9 a% M7 |+ a# [; C6 [* B
ANSI/VITA 46.6-2013 (S2025)        Gigabit Ether*** Control Plane on VPX1 z' W  K6 Y- Q$ r
ANSI/VITA 46.7-2012 (S2024)        Ether*** on VPX Fabric Connector9 n" m- d& M- i& V
ANSI/VITA 46.9-2018 (R2024)        PMC/XMC Rear I/O Fabric Signal Mapping on 3U and 6U VPX Modules Standard. T# f: G! q& y: W8 F0 V& p& D
ANSI/VITA 46.10-2009 (S2024)        Rear Transition Module for VPX
( \' E/ V* K3 k3 B  z+ iANSI/VITA 46.11-2022        System Management on VPX2 B) s6 M5 p) y
ANSI/VITA 46.30-2020        Higher Data Rate VPX, V% Y! ~2 o" ]# B/ T; h
ANSI/VITA 46.31-2025        Higher Data Rate VPX - Solder Tail in Blind via$ j% F8 B6 y8 |  d
VITA 47 Bundle                VITA 47 Standards Package         Construction, Safety, and Quality for Plug-In Modules Standard1 a- J6 x1 l$ S0 C! k
ANSI/VITA 47.0-2019        Construction, Safety, and Quality for Plug-In Modules Standard  \$ g, O& [& f! o  O8 }
ANSI/VITA 47.1-2025        Common Requirements for Environments, Design and Construction, Safety, and Quality Standard) j# s% v; k4 `- J, h: Z+ e' [
ANSI/VITA 47.2-2019        Class 2 Requirements for Environments, Design and Construction, Safety, and Quality Standard& m  u' U# g) \# ?
ANSI/VITA 47.3-2019        Class 3 Requirements for Environments, Design and Construction, Safety, and Quality Standard& \. j4 E0 f, j9 ?$ ^/ ?
ANSI/VITA 48.0-2022        Mechanical Standard for Microcomputers using Ruggedized Enhanced Design Implementation (REDI)
- m; d& w4 D  iANSI/VITA 48.1-2020        "Mechanical Standard for VPX REDI Air Cooling"
  N$ S- ?6 o! oANSI/VITA 48.2-2022        "Mechanical Standard for VPX REDI Conduction Cooling"8 C0 s% g: E) S3 Z" D7 ]
ANSI/VITA 48.4-2022        "Mechanical Standard for VPX REDI Liquid Flow Through Cooling"
, J$ x3 p2 C5 W' [: u/ p" @ANSI/VITA 48.5-2010 (R2017)        "Mechanical Standard for VPX REDI Air Flow Through Cooling, 1.52 ""itch"# \, P) K. B2 B4 Q. x. N
ANSI/VITA 48.7-2023        "Mechanical Standard for VPX REDI Air Flow-By &*****;Cooling"
, \0 E; Q$ i# d! IANSI/VITA 48.8-2022        "Mechanical Standard for VPX REDI Air Flow Through Cooling, 1.0 ""to 1.5 ""itches"! F2 L5 H( h& p  |" F+ H
ANSI/VITA 49.0-2015 (R2021)        VITA Radio Transport (VRT) Standard
5 b# `2 R; I3 B# aANSI/VITA 49.1-2015 (R2021)        VITA Radio Link Layer (VRL) Standard
" |1 u$ c& P4 P2 [; cANSI/VITA 49.2-2017 (R2024)        "VITA Radio Transport (VRT) Standard for Electromag***ic Spectrum: Signals and Applications"
' K5 V3 z6 s# _: lANSI/VITA 49A-2015 (R2021)        Spectrum Survey Interoperability Standard
& z% `- G% R3 t% X2 pANSI/VITA 51.0-2012 (S2024)        Reliability Prediction3 S4 r0 e; s) A  J. \% N
ANSI/VITA 51.1-2013 (S2025)        Reliability Prediction MIL-HDBK-217 Subsidiary( P: S1 `* G" h9 a" O1 c* K
ANSI/VITA 51.2-2016 (R2025)        Physi** of Failure Reliability Predictions4 D. K( q3 l8 k" z
ANSI/VITA 51.3-2010 (S2024)        Qualification and Environmental Stress Screening in Support of Reliability Predictions* _. m& R3 O3 j7 c# w$ q1 p
IEEE Std 2818-2024/VITA 51.4-2024        Reliability Component Stress Analysis and Derating/ B2 g+ d- J/ b* X) ?
VITA 53.0-2010 (S2022)        Standard for Commercial Technology Market Surveillance
( O- |/ u% K8 L2 d/ \VITA 57 Bundle                VITA 57 FMC and FMC+ Bundle* e) S# A5 V- {: @+ w! ^( k
ANSI/VITA 57.1-2019 + Errata        FPGA Mezzanine Card (FMC) Standard& {7 ^8 w3 v( P( n3 A
ANSI/VITA 57.4-2018 + Errata        FPGA Mezzanine Card Plus (FMC+) Standard0 s8 w' c( T  N( X
VITA 58.0-2009 (S2022)        Line Replaceable Integrated Electroni** Chassis Standard) |) J6 O& e* d0 B
VITA 58.1-2013 (S2022)        Line Replaceable Integrated Electroni** Chassis Standard, Liquid Cooled Chassis
- O$ r) D. O/ {+ lANSI/VITA 60-2012 (R2018)        Alternative Connector for VPX
. G: {4 c; @8 u7 }5 FANSI/VITA 61.0-2022        XMC 2.0
& Z$ ^& Q, y1 A5 p# yANSI/VITA 62.0-2022        Modular Power Supply Standard% a# w3 s& |2 @% ]
ANSI/VITA 62.1-2023        Three Phase High-Voltage Power Supply Front-End in a 3U Plug-In Module Standard* \' Y& D5 m2 b6 ~. d' z" v
ANSI/VITA 62.2-2020        Modular Power Supply Standard for 270v Applications
% H! H; \& u9 t: bANSI/VITA 63.0-2015 (R2022)        Hyperboloid Alternative Connector for VPX VITA 65 Bundle        OpenVPX (VITA 65 and VITA 65.1) Bundle
2 k2 W) J, X7 [5 wANSI/VITA 65.0-2023        OpenVPX System Standard
  B3 }* V7 w0 q% Q* u# YANSI/VITA 65.1-2023        OpenVPX System Standard –Profile Tables
4 Y; f2 \1 H( e$ Q# H' T, `ANSI/VITA 66.0-2016 (R2025)        Optical Interconnect on VPX –Base VITA 66.1-2012        Optical Interconnect on VPX –MT Variant
% K# {1 e/ B( t+ e2 u" a1 cANSI/VITA 66.2-2013 (S2025)        Optical Interconnect On VPX –ARINC 801 Termini Variant/ K( U% d; q+ |. s- ]0 n- n
ANSI/VITA 66.3-2012 (R2018)        Optical Interconnect on VPX - Mini-Expanded Beam Variant. n5 j# }  T  h# C
ANSI/VITA 66.4-2016 (R2025)        Optical Interconnect On VPX –Half Width MT Variant
2 c1 I9 z, ~* x' sANSI/VITA 66.5-2022 +Errata        Optical Interconnect on VPX - Hybrid Variants
4 U8 s, C0 @8 {ANSI/VITA 67.0-2019        Coaxial Interconnect on VPX –Base Standard7 ^' t, l( i" J5 ]% j
ANSI/VITA 67.0-2019        Coaxial Interconnect on VPX –Base Standard4 ~# H4 I# Z" Z  E' Q
ANSI/VITA 67.1-2019        Coaxial Interconnect on VPX, 4 Position SMPM Configuration         Coaxial Interconnect on VPX, 4 Position SMPM Configuration* e3 o5 r9 W1 Q4 Y  W- Z( w
ANSI/VITA 67.2-2020        Coaxial Interconnect on VPX, 8 Position SMPM Configuration9 U, W1 j2 c' p" n$ J' f& x
ANSI/VITA 67.3-2023        Coaxial Interconnect on VPX - Spring-Loaded Contact on Backplane
2 w" o7 u# P' I" }ANSI/VITA 68.0-2025        VPX Compliance Channel Standard
& W. A6 X0 i+ m: q8 s# kANSI/VITA 68.1-2025        VPX Compliance Channel - Fixed Signal Integrity Budget Standard; q+ z0 f" G. C2 r# D1 B* s
ANSI/VITA 68.2-2021        VPX Standard S-Parameter Definition
( w* i9 S( U& s, b9 z2 OVITA 68.3-2024-VDSTU        Reference SI Model Standard for Gen4 and Higher Speeds
) j5 Q. t. {+ E+ j& e1 C) sANSI/VITA 74.0-2022        Compliant System Small Form Factor Module (VNX) Base Standard
& i6 `; S! B( Z# \) x8 X1 fANSI/VITA 76-2016 (R2021)        "High Performance Cable -Ruggedized 10 Gbaud Bulkhead Connector for Cu and AOC Cables"
" m7 d. G4 e" J6 n0 l9 d1 p- lANSI/VITA 78.0-2022        SpaceVPX System Standard
) a; w. c9 S; Z- e9 gANSI/VITA 86-2025                High Voltage Input Sealed Connector Power Supply
! h& E- s8 d: eANSI/VITA 87.0-2024        High Density (HD) MT Circular Connector - Type 12 C; s2 t& B5 J! g: F& z
ANSI/VITA 88.0-2021        Switched Mezzanine Card Plus (XMC+) Standard- j1 R; n; f3 i9 t7 N
ANSI/VITA 91.0-2024        Connector for Higher Density VPX Applications
3 k3 h* _( x1 J2 J9 |' M7 `
% y) {1 |. ?7 E8 H! u7 ^! H3 P6 yDownload Contact:   1395833280@foxmail.com
2 m/ n) X4 ?( T% j                td@outlook.com: m" Y1 f4 ]3 @
# ~& w: N3 {( d" A8 V
/ O7 u1 Y: @& Y; R" b* r7 Y, z1 j& X% M" y9 u( b5 m5 Q
