查看: 3573|回复: 0
AP5199平均电流LED驱动IC 0-450V 10A大功率LED车灯驱动IC
发表于 2023-3-24 17:03:12 | 显示全部楼层 |阅读模式
AP 5 199
LED Driver
Description
The AP5199 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike AP5160,this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. The AP5199 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an External control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input.
Typical Application Circuit
Features
● Fast average current control
● Programmable constant off-time switching
● Linear dimming input
● PWM dimming input
● Output short circuit protection with skip mode
● Ambient operating temperature -40OC to +125OC
● Pin-compatible with the AP51 99
Applications
● DC/DC or AC/DC LED driver applications
● LED backlight driver for LCD displays
● General purpose constant current source
● LED signage and displays
● Architectural and decorative LED lighting
● LED street lighting
