查看: 1980|回复: 1
大佬们,为什么我LED显示器没有显示255之后的数字呢
发表于 2023-4-17 18:43:22 | 显示全部楼层 |阅读模式
#include<reg51.h>
#define uint unsigned int
#define uchar unsigned char
uchar times,g,s,b,q;
uint num[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uint c;
void delay(uint z)
while(z--);
void counter() interrupt 1
times++;
void LED_duan(uint c)
q=c/1000;
b=(c%1000)/100;
s=(c%100)/10;
g=c%10;
void LED_xianshi(uchar q,uchar b,uchar s,uchar g)
P2=0X01;
P1=num[g];delay(360);
P2=0X02;
P1=num;delay(360);
P2=0X04;
P1=num;delay(360);
P2=0X08;
P1=num[q];delay(360);
void main()
TMOD=0X06;
TH0=0;
TL0=0;
EA=1;
ET0=1;
TR0=1;
times=0;
while(1)
  c=times*256+TL0;
  if(c<=9999)
   LED_duan(c);
   LED_xianshi(g,s,b,q);
  else
   times=0;
   TL0=0;
联盟顾问
发表于 2023-4-17 18:43:54 | 显示全部楼层
改一下定义的数据类型就行了
