查看: 2217|回复: 0
Wallys/IPQ4018/IPQ4028/Wave2Access Point Wireless Module Dual band 1...
发表于 2022-6-24 09:35:41 | 显示全部楼层 |阅读模式
IPQ4018/IPQ4028 802.11ac Wave2
IPQ4018/IPQ4028 2x2 2.4Ghz 2x2 5Ghz Industrial-grade
DR40X8H
https://www.wallystech.com/Routerboard/DR40X8H-Qualcomm-IPQ4018-IPQ4028-2T2R-Dual-Band-2-4GHz-5GHz-high-power-support-MU-MIMO-802.11ac-Wave-2.html
Wallys (http://www.wallystech.com) has its own software development team, we have the professional hardware and software engineers, can be customized for you the best solution, we have based on Qualcomm IPQ6010 / IPQ9074 IPQ6018 / IPQ4019 / IPQ4029 series products, if you have any needs, please feel free to contact me: sales3@wallystech.com
Features
  • Featuring with industrial-grade IPQ4018 chipset
  • Integrated with 2x 2 5G high power(27dbm per chain) Radio module and 2×2 2.4G high power(27dbm per chain) Radio module
  • Support 5180GHz to 5.825GHz Frequency Range;
  • Support 2.412GHz to 2.482GHz
  • Support 2 x 5G MMCX Connectors and 2×2.4G MMCX
  • 20MHz/40MHz/80MHz Bandwidth
  • Support 11ABGN/AC
  • RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Applications
  • Security Surveillance
  • Commercial radio coverage
  • Hotel Wireless application
  • Country coverage
  • Forest fire protection engineering
  • Some special scene application
Product Description
524wifi AP40X8H based on IPQ4018 chipset is an enterprise wireless module integrated with 2×2 5G high power Radio module and 2×2 2.4G high power Radio module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +60
oC
Storage Temperature Range
-65 to +105
oC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
IPQ4018(Quad core ARM Cortex A7 at 710 MHz)
Antenna Connector
2 x 5G MMCX connectors;2×2.4G MMCX
10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector
1xSFP fiber module connector (optional)
3G/4G connector
1xminipcie 3G/4G connector support with two sim card
USB connector
1xUSB 3.0 connector
POE
24V~48V passive POE
DC Jack
24V~48V power supply
ROHS Compliance
YES
Dimension
115mm x 105mm x 16mm
Nor Flash
2MB~32MB
Nand Flash
128MB
DDR
256MB
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
802.11a
6 Mbps
27dBm
30dbm
±2dB
54 Mbps
23dBm
26dbm
±2dB
802.11n HT20
MCS0, MCS8
26dBm
29dbm
±2dB
MCS7, MCS15
22dBm
25dbm
±2dB
802.11n HT40
MCS0, MCS8
25dBm
28dbm
±2dB
MCS7, MCS15
21dBm
24dbm
±2dB
802.11ac
MCS0, MCS10,MCS20
25dBm
28dbm
±2dB
MCS9,MCS19,MCS29
19dBm
22dbm
±2dB
Operating Mode
Data Rate
Sensitivity
802.11a
6 Mbps
-96dBm
54 Mbps
-78dBm
802.11n HT20
MCS0, MCS8
-92dBm
MCS7, MCS15
-73dBm
802.11n HT40
MCS0, MCS8
-90dBm
MCS7, MCS15
-70dBm
802.11AC HT40
MCS0, MCS10,MCS20
-90dBm
MCS9,MCS19,MCS29
-67dBm
802.11AC HT80
MCS0, MCS10,MCS20
-88dBm
MCS9,MCS19,MCS29
-62dBm
Radio TX Specifications(2412MHz-2482MHz)
